Did you get your problem solved? Perhaps, contact PS Audio Tech. The response time for me has been great for questions. Reinstall most current firmware .39. Possible sensor issue?
Frode I hope your P10 will not need to go to service.
It seems to be pretty slow in the Europe in my own experience…
My P10 have been sent to service in September and till this day I don’t have it back (3 months…) - now the service is waiting for regenerator replacement part being sent from US…
I assume you have unplugged and plugged it back in? Turned the non-function “green” outlets off and back on? The reset button seems to be for the breaker that should cut off all power but I would try pushing it anyway just in case (you probably have by now). I can’t think of anything that isn’t fairly obvious. Otherwise I would suggest contacting Alex to see if he has any ideas.
