P12: How to get multiple meters on 1 screen?
Like this picture on the official site under the “Power Regenerators” category? Pretty sure it’s a P12. Thanks.
I’m not sure if it works the same for the P12, but I have a P20 and the screen is a touch screen. If the P12 works the same, you should be able to drag your finger across the screen left to right or right to left until you get to the screen with the multiple meters.
Good luck!
The P12 does have a touch screen, but swiping left or right changes the meter, but does not have an option for 3 meters in one screen that I could find. Upgrade time?? :wink:
I had asked the same question several years ago. James told me that the photo of the P12 screen was a mockup and that it had never made it into production
