P15 for BHk 300s
Currently, I owned DSD and P15, and wish to upgrade my system to BHK 300s and BHK preamp.
Can p15 handle all that? Thank you! :smiley:
Yes you should be fine. I have bhk 300s, bhk pre, dsd, anthem avm 60, emotiva XPA 11 and a SVS sub all running off a p15 with no issues at all. The p15 has never gone above I think 70% before.
If you are running Apogee Scintilla’s at 1ohm load they will make a toast out of your bhk amps and P15. So the question is what speakers do you have and how loud you play them equals to power draw?
Any normal speakers and listening volume and you should be fine with P15. P20 is of course better if you can take the hit.
Welcome!
This thread may be of interest: click.
Yep. P15 here feeding 2 BHK 300’s, PrimaLuna EVO 400 preamp, PrimaLuna EVO 100 DAC, Auralic Aries G1, Roon Nucleus+ and TT/phono preamp. Never gone above 58 percent. Driving fairly sensitive Focal Sopra N2s, so doubt I am ever driving the BHKs over 5-10 watts continuous, but even at occasional very loud volumes, the needle rarely jumps by 50 watts max. YMMV.
