The perceived wisdom from PS Audio is that you don’t use anything in front of a power plant.
Well, we all know that a better power cord driving a power plant will improve the sound.
The better the electricity going into a power plant the better it will produce power.
Some of the patrons of this website use a AQ Dragon 48 to drive their P20.
Background,
I’m in the UK and run a combined music and home theatre system so I’ve a lot of cables behind my two racks.
I’ve had my P20 for just over a year now and when it’s on and everything else is off I can hear a faint low frequency hum.
Thinking this might be caused by some DC on the line I auditioned the Isotek EVO3 Syncro Uni which is claimed to remove DC on the line.
EVO3 Syncro Uni - IsoTek – The Power To Perform (isoteksystems.com)
In Use.
When I first received it I expected it to have a male IEC and female IEC at each end but was surprised to find it had a power socket at one end.
I quickly press ganged a new power cord into it with an ordinary mains fuse.
Initial findings weren’t great.
The volume seemed to increase dramatically, treble was harsh and the bass was one note.
I ran it like that for a day and enquired with Isotek about product burn in, which they disputed,
“The EVO3 Syncro Uni is rebalancing the mains sine wave, this is done immediately when connected. The now rebalanced sine wave will have an effect on the attached electronics, depending on how they are designed the effect can be immediately or take some time.”
The following day I got a better power cord and fuse and let it run for a further day.
Initially I had the new power cord going from the wall to the Isotek and my regular P20 power cord going from the Isotek to the P20.
With the better power cord I now reverted to my P20 power cord going from the wall to the Isotek and the new Power cord going from the Isotek to the P20.
After two days the sound was transformed.
Volume level was back to what I usually expect, the treble had returned to what I’m used too, soft, feathery and extended, with no harshness. The bass was back.
What had improved was that there was more detail coming through, allowing separate musical strands within the song(s) to be followed much easier with vocals also easier to follow. Also vocals were ‘compact’ and very much in size, keeping with the rest of the soundstage. The music extended even further beyond the sides of the speakers than what I was used to.
What I think is happening is that the Isotek is reducing the noise floor level of my system even further, allowing the above improvements to be heard.
The low level hum that was there when only the P20 was operating is gone but what has replaced it is a low level hum now from my amps when they are on. This can’t be heard when music is playing. This hum disappears when the amps are switched off.
Not sure whether either the ‘old’ hum or ‘new’ hum is being created by the close proximity of all the cables I have at the back of my racks for the two systems. It’s impossible to do proper cable management with so many cables all close together.
My system was already excellent and has given me much pleasure but the Isotek has definitely improved it, giving me even more enjoyment.
The only downside is having to buy an additional quality power cord.
