Hi,
Currently i have version *.39 and saw there’s an *.41 firmware update for the P5.
Any significant improvements that worth the “trouble”?
What exactly changed?
Sorry if this has been asked before (I did search but couldn’t find).
Regards
Hi,
Regards
Anyone?
Mine had the original version (.2?) and I upgraded to .41. When I did, I had a problem where no data was present on the “scope” screens. I called PSA and James sent me some files which i downloaded onto a reformatted SD card and problem solved.
.41 gives you some additional functionality over what I started with, like the ability to select MW levels.
I noticed absolutely no difference in sound quality. If your incoming power is reasonably stable, I wouldn’t bother even though I am by nature a tinkerer.
Thank you Ron.
