Just found a latest update called “P5P10 .41 Upgrade” on downloads.
May I know any new fixing for this “P5P10 .41 Upgrade”? and should I use this updater to upgrade my P10?
the existing firmware version on my P10 is .39
There is a minor bug fix having to do with the front screen display appearing upside down in some instances. You won’t need it.
