PIN Assignement Direct Stream DAC MKII for I2S
Hi, I just bought a PS Audio Direct Stream DAC MKII and would like to use it with my HiFiRose RS 130 Streamer. The Rose has I2S Output with 2 different modes and I would like to be sure which mode to use. I attach a picture of the I2S PIN Assignement at the Rose RS 130. Do I have to switch something on the PS Audio DAC which is possible in the PS Audio menu
Thank you
Welcome!
Thank you, happy to become a member of this family
As far as I know there is no way to change pin assignments on the PS Audio DAC.
“A Mode” on your Rose most closely matches the PS DAC.
