I don’t listen to the multi-channel versions…yet.
I have had the PST for quite some time and you heard it a couple weeks ago. If you are gaslighting me with the intention of bringing over the Ethos instead, then I admire your tenacity in trying to make a new Gryphon disciple.
Drop off the Ethos then I will bring it to Greg to try out. Lol
I am going to order the SACD. Frankly, Most SACD sounded the best in PST than any other DSD files I have, it sounds better than any DSD256 playing through my new server, I think.
I know you are going to tell me to get a better server, but I can happily live with my Summus 2 for a while, as long as I also have PST ![]()
It’s a hybrid SACD so you’ll be able to rip the Redbook layer easily and the DSD layer less easily.
I’m perfectly happy with my vintage pressing of PF Animals. Oh wait are you telling me there’s something better? Damn!
I’m confused. If I order the SACD, can I still play it on my Blu-ray and get the 5.1 surround? Or do I just get the Blu-ray version for that?
I am not certain you can get a better server. ![]()
Your assessment carried extra weight! Thanks😄
It says Hybrid so you can play it on your CD player or regular Bluray. But heck stream the hi res with your subscription to Tidal or Qobuz if you have one.
Some of the hi-re streaming sounds so good, and bettered CDs for sure, unless you have Gryphon Ethos level CD players.
But SACD is a different matter.
I ordered the SACD. Looking forward to it!
I am listening to and enjoying my lesser, Euphony PTS server. (Cabin system)
I am a Euphony fanboy. When version 4 is released soon I will install it on my Pink Faun.
Version 4 should be, hopefully not like the new AirLens and DS II, released soon.
Are you still using the Pink Faun as a core and the MU1 as the endpoint?
Currently yes.
If you listen to Pink Floyd through a Pink Faun you will leverage Pink Synergy. It is also enhanced by a Victoria’s Secret tshirt. FYI, this does not apply to Punk Floyd.
I don’t have any Victoria’s Secret of a Pink Faun so I’ll have to take someone’s word for it.
I could bring my Pink Faun to you to try.
I think you need to bring it for @straightwire. He needs to get streaming!
