Poor sound quality from Airlens
Hi All,
I recently purchased PS Audio’s Integrated Stellar Strata MK2 and the Airlens. Not pleased with the sound quality because my previous streamers (Cambridge CXN and Sonos ZP) has a more natural sound when hooked up to the Strata MK2.
The Airlens is connected to the Strata MK2 via an AudioQuest Cinnamon HDMI cable from 2011 and Ethernet, it has a dull tone to it (no trebles but bass levels are OK)
I have not experimented with Coax yet.
Any suggestions on how I could improve the sound quality?
Thanks.
How many actual hours of playing music with the Airlens? Am I reading correctly you are using an HDMI cable from 14 years ago long before there were components with I2S audio?
Try another hdmi cable. Doesn’t have to be fancy, try one you might have on the tv.
For my Airlens to Strata (MK1) connection I used an AudioQuest Thunderbird 48 HDMI cable - it was quite good, much better than the built in streamer in the Strata. I was also using a Cinnamon Ethernet cable, the HDMI cable made a much bigger difference than the Ethernet cable in that setup.
It could be the DAC assumes it receives data with the preemphasis bit set. That’s a frequent hassle with I2S.You might want to check if your DAC assumes preemphasis, maybe there is an indicator LED, or a setting to ignore the preemphasis bit. Another alternative is to try material other than 44.1/16, since only redbook allowed for preemphasis. Or try not using I2S for a check.
Around 5 hours played by me. Also PS Audio runs them (for burn in purpose) for a while before shipping.
I tried using a basic HDMI cable with came with my Sony TV in 2025. Still no difference in sound quality.
Tried this, no luck :confused:
I’m not aware of the preemphasis bit set. I’ll look into these settings. Thank you sir.
Try a different HDMI cable. I first had an Audioquest Cinnamon, and it sounded very dark and had little resolution. I switched to the Wireworld Platinum Starlight 48 HDMI cable, a much more expensive cable, but it elevated the sound significantly. It provided much more resolution and more details.
You are half way there. But a good spot to rest. A bunch of us think the Dragon 48 is tip top. Except for that one guy. Don’t be that guy. But what you have right now is very good.
Something is not right. I have never heard a complaint about the sound of the Airlens.
And I doubt many owners or reviewers used a cable the cost as much s the streamer.
Hi all,
After switching off the pre emphasis the sound quality improved drastically. Issue is solved now. Thank you all for the comments.
