I know this topic has been beat to death, however, I think I have a new twist on this issue.
When discussing popping sounds on the DS1, it’s typically been in reference to going to PCM to DSD or vice-versa. The culprit being a change in resolution.
I just wanted to point out that the change in format is not required. I recently converted my collection to DSD only. It still POPs if there is a changed in resolution.
I think the issue is still relevant because I’ve read that this has not gone away 100% with the DirectStream Mk. 2.
I’m hoping that if this in fact provides new information, and tech wizard @tedsmith discovers a solution for the Mk.2, there will be a way to pass it down to the Mk. 1.
Yes, most of the popping on the Mk I are due to a bug in Sunlight. When I was working on Sunlight I had the ramp down and ramp up times for muting transitions set to a small number so I could hear them. I forgot to set it back to 10ms (or so) before I released the code. Roon does indeed “push Sunlight’s buttons” more than most other sources.
I’d love for a Sunlight version 2, or whatever. At least with it, owners know that it was Ted’s final idea with the unit. Really, it is quite owed to existing (and future) owners.
edit: I might just explore older versions too, since I don’t have much material that needs quad rate.
I run Jriver also for many years and don’t have pops. I have it set to gapless with a 2000 ms buffer. Otherwise when streaming Radio Parade, I get cutouts near the end of tracks with any DAC not just the DS. I am currently running v 29 however I have had it set this way since v 21.
It feels wrong to leave a bug, or at least any unintended code that remained for test purposes, in the firmware as the bon voyage to the unit. I recall and appreciate how carefully Ted and PS Audio were in releasing Sunlight, and understand that these things happen. My career was devoted to tracking and releasing changes to customer facing systems. Also, I’m currently available…and in Colorado.
I started adding delay to everything my roon audio signal, and it seems to help. My PST and BHK Pre have pops, too. It’s such a pain to figure out which part of my system is responsible sometimes. It distracts me from the music, which is the very last thing I want in my hifi.
