Someone here recommended a Raven Soniquil power cable as an affordable yet very competent upgrade. Whoever you are, my heartfelt thanks.
I have Belden BAV 12 gauge cables feeding my Stellar GainCell DAC and PerfectWave SACD Transport and was ready to get a third for the P3. Checked out the Raven 10 gauge (on sale!) and it arrived today.
Right out of the box, not even warmed to room temperature, and it blew my mind. I had barely finished hooking it up when my wife said, “Holy cr@p, that is incredible!” I was walking back to my seat when the FM Tuner played and the voice of the announcer was crisp, almost visual, and so well separated from the background. My wife is a retired speech/language pathology professor and knows the human voice–she was blown away. I was too.
Played a series of CDs/SACDs and everything is cleaner and crisper, better separation of instruments and a wider sound stage. The big thing is the clean sound and the accompanying richness.
For the price this sounds like a great cable for you. I was going to suggest something, but even Anticable Level 3 PC is double the price of yours. However, it is a great power cord should you ever consider one that sounded better than many cords in $1000 range
If you can mount the plugs yourself you can get a fully shielded (!) cable with ferrite on every single string, and they are awesome and a perfect fit for the PP3 (in fact I sold my Synergistics and Wireworlds for these). I have five of them now.
Here is another idea. Get a pair of Furutech IF50 NCF plugs, and put them on whatever cord you have now. The SQ elevation beats most $1k cords easily. Just do not buy from Aliexpress!
Most of my power cords are Furutech with NCF connectors. At $350-$400 per connector retail, it’s kind of up there (although VH Audio is offering 20% off right now). I am not convinced that they sound any better than a decent Wattgate at half the price or DH Audio at a quarter the price. I did look at those Raven Soniquil cables mentioned above just now and wow they appear to be straight forward, well built, quality cables. If this weren’t such a compelling hobby with potential for the DIY stuff I love, I’d regret all the time and money I’ve poured into it. I think I am a sucker born every other minute.
Sucker? Don’t we all? NCF plugs pair with some cables better than others, and I should have mentioned that.
Clean out our bathroom and walking closet. Man, I have more than two hundred pairs of golf polos and pants. I need to get rid of some. This may take two days to clean.
Hi, an acquaintance of mine owns a Power Plant P3, he used the Voodoo Tesla 6AWG and Voodoo Dynasty 8AWG as the incoming power cable. With the Voodoo Tesla, he can clearly hear that the system sounds louder, with more detail, energy, and clarity.
Unfortunately, I haven’t been able to hear it for myself.
I find that a bit strange. Isn’t the regenerator normalizing the AC wave into a clean signal?
Of course, I read Paul’s explanation.
But I still have questions. Does the Voodoo Dynasty cable actually restrict the supply of current?
Is an 8 AWG gauge insufficient? Is it not enough to ensure “clean” power delivery?
This is a high-quality power cable with a fairly high price tag.
And if the output current differs when using one cable versus another, is it possible to see this on measuring instruments?
It is not just current flow. The apparent louder volume is most likely due to the lower noise floor. You are simply hearing more details and information; it is like a layer of veil has been removed. The good cables, not just power cables, did that to me more than once in the past. But once the cable reaches a certain level, the improvement from a higher-level cable will improve less and less (without hearing more volume increase).
I understand that this is intended as a comparison between a standard electrical cable and a specialized, high-quality audio cable. However, the comparison actually involved two high-quality, expensive audio cables. Does this mean that the Voodoo Dynasty is of low quality and failed to reach a certain level?
Since I am not familiar with both of these Voodoo cables so I can not say for sure. But 8 AWG is overkill for any power component already since most of the behind-the-wall cables are only at 12 AWG. So, the only logical explanation is Tesla is at a higher level than Dynasty and is able to remove more background noise, or you have a defected cable.
But this can also be said about cable quality too, so behind the wall cables are as good as it gets regardless of the power cable? I know you don’t believe that.
I also believe that 8 AWG is more than sufficient for the needs of the regenerator. But if the regenerator creates an entirely new current, why does background noise still end up in the output current? The cable has no defects.
Good questions and observations. I have accepted the fact that I’ll never really understand why or how power cables make a difference to power regenerators, or for anything else for that matter. But I’ve joined the cables matter club anyway
Of course I’m also in the cables matter club. Specifications, materials, construction, all of that is highly significant. But in certain instances, like this one involving a power regenerator and VooDoo cables, I find it easier to believe in a placebo effect than in something inexplicable. Still, I do hope there’s a rational explanation for it.
When I thought hard on it in the past I came to the conclusion that the better the cable, hence in the best of them the cleaner the power, attached to the regenerator, the better the regenerator was able to work, and less to “remove” and perhaps less noise generated within the regenerator. I always heard differences between cables and the regenerator, and also fuses. Makes sense to me ultimately.
