Good to know. This room is appx. 3500 cubic feet. I am looking forward to hearing them in person in my room. I think they are a few weeks out still as I ordered them painted and he sends them out to a local paint shop for that option.
@scotte1 - thanks for the info, will digest. The room dimensions are set; however, the acoustic design is partially done. I will be measuring the room initially without any treatments and slowly build it out.
Was it possibly this amp:
https://www.decware.com/newsite/SE84UFO25.html
I have a Monoblock version of this amp (a bit more powerful) and they ended my amp envy. Period. Amazing.
I have on my list of winter chores to tighten the ground/neutral bar and clean and seal the ground rods.
I have two dedicated 10awg, one feeding P10 and the other feeding all things not on the P10 mostly AV gear. Separate phases.
I used a silver paste on the conductive breaker connections and outlet terminations when running the circuits. I expect it will last many years. I’ve not messed with alternative breakers.
Any other ideas for power maintenance?
Yes!
Pairs very well with the Zu I bet
