stevem2 said Try the "dim" button on the remote?If you mean the "display" button, it does nothing when I press. The display blinks a bit, indicating some sort of signal is received from the remote, but that's it.
That’s what I meant. Did you ry disconnecting the power? Can’t think of much else.
stevem2 said That's what I meant. Did you ry disconnecting the power? Can't think of much else.Hey Steve, I tried that, nada. Thanks for trying. I left a message with the factory tech support. Maybe he can help
