scirica said Just watched the video and I'm pretty excited. Just want to make sure I understand this correctly...I’m running Roonserver on my HTPC connected to the DS DAC via USB today. (I have a Bridge 2 also but we’ll set that aside). USB out from computer to LanRover #1, then Cat5 to my network hub/modem. (1gb switch in place). Cat5 then goes in to LanRover #2, and output is USB to DS DAC. So far correct?
For the DS DAC to operate, do you still need the PS Audio USB driver installed on the HTPC? I’m assuming so, but just checking. Also, do we know the input voltage of the LANRover for those that would like to replace the wall wart with a LPS?
Who gets to beta??
David saidPaul,
Refresh my memory, will the LANRover need a dedicated ethernet cable, or will it use the LAN, or can it do both? Because currently trying to use the LAN, 3 10gb switches (HP commercial switches) using CAT7 cables, from a laptop with MC21 to the DSJr. DAC bridge 2 and I still get constant dropouts. A dedicated CAT7 cable would probably work much better.
No, it uses the LAN. Or, a dedicated cable, but what’s unique about this guy is that it seamlessly goes over the LAN. And it sounds simply amazing. Can’t live without it. I am addicted.
