Anyone with the above gear please help.
JUST installed my NEW May KTE Dac and connected to my Ps SACD Transport vis A.Q. Dragon HDMI.
What setting do you use on the May Dac to sync up with th Ps SACD Transport ?
Thanks,
Tom - NJ
Thanks,
Tom - NJ
ALT2 is what I use between the PST the Holo.
I just got my May DAC on Monday as well. I use ALT2.
2 replies and you both said ALT 2.
Looks like the ALT 2’s have it !!!
Thank You
Tom
Thank You
Tom
ALT 2 worked like a charm and first listen was amazing right out of the box !
I looked at Kitsune site and see nothing regarding break-in time (hours) for the May KTE.
Do you have any idea how long until its fully broken in ?
Thanks,
Tom
Tim says 4-500 hours but I didn’t find the changes to be that dramatic after about 100 hours. It appears that the same is going to be true of the Spring 3 KTE I received yesterday afternoon. I’ve got an old OPPO DVD player from around 2005 that I keep around just for break-in duties. I just put it on repeat and let it go in another room for 10-14 days.
