Is it possible to connect the PerfectWave SACD Transport to the Sprout 100? If so, how is it done? I may have an opportunity to purchase a PST but the only thing I have with a DAC right now is the Sprout 100. Thanks all!
I had a feeling that wasn’t going to work out. Oh well, wishful thinking I guess ![]()
You can connect the coax output of the PST to the optical input of the Sprout using a device such as the iFi SPDIF iPurifier 2
No worries! I hope he finds a solution that helps him enjoy his music!
Thanks for the info. Should probably just wait until I can afford a better system (only have a desktop). Found a used PST for just under 4K but using it with a Sprout might be a waste.
