PWD mk2 firmware
hi everyone which is the best firmware to use with bridge 1 in a PWD 2? can i use the latest firmware or because it is bridge 1 should i be using an early version?
thanks Mike
If you append your post with @jamesh it should get directed to the inside guy who can provide the definitive answer.
You should go with 2.4.6. All of the latest firmware address the Bridge II, and prevents the Bridge I from working that well.
will do thanks for the heads up
I am have updated my pwd mkii to 3.04 and have problems with the bridge1. Is there a way I can set it back to 2.4.6? @jamesh
Welcome!
See, herehttps://www.psaudio.com/support/downloads/ and specifically here.
