Apologies, as I know this has been addressed before, but I simply can’t find it…
I am replacing the power cables to my preamp and amp, and they are both connected to the P5, currently.
Is the proper and safe method as follows…? And if not, can someone please reply as if I am a 5 year old, so I do not blow up my house? LOL! Thanks in advance!
Power each component via the power switch
Power down the P5
Remove existing power cables, replace with new ones
Power up P5
Flip on the power switch for each component connected to the P5
I would insert as step 1 “Power down amplifier” to avoid any nasties from shutting off other components reaching the speakers. Trust me, I’ve done that and it’s not pleasant! I would also clarify that your step 1 is “Power down each component via the power switch”. Otherwise, you’re good to go!
Thanks, everyone! Changed out the cables without blowing up the house LOL! Nowhere near as dramatic a change as when I integrated the P5, but there seems to be some finer detail, and imaging. Hoping to hear more over time, but either way, it made sense to make the changes, given the investments thus far into my rig.
