Need help - I just made a roon server. I just need to hear Tidal and music files 24 - 192 - it sounds like it is getting worse lol - please send photos … as my english is not so good thanks for the help
An LPS feeding NUC will help. What does server use for power? Are you using USB to DAC or Bridge 2 ethernet connection.
Everything in Digital chain on LPS and good digital cable recomend Inakustik Referenz and an UltraRendu and Matrix using i2s RAL HDMI really helped clear out noise.
I have Roon on my laptop until I researched what’s best to use. then the server -net cable for hub -to Bridge 2. So I just wish the best sound for Tidal and for music files 24-192.
MIchael
If I were you i’d join the Roon Community forum. Lots of tinkerers there, and I bet you could get your question answered.
That said, I think many have discussed the limitations of the Bridge II. Do you have any other way to connect your server to your DAC? Could you build a separate raspberry pi streamer and go USB/SPDIF, etc…?
I have the same AKASA fanless case with a similar i7 NUC. I run ROON ROCK on it and it’s not only stable but sounds great as a server. I use an LPS but that won’t make your music sound terrible. Have you looked a the Roon settings to make sure that the native signal is what you’re delivering? Just in case the DSP is changing the stream?
I had an issue like this a long time ago and I had to update the Codecs that you originally installed when building your Rock server as it is not updated automatically with Roon updates. I would try this
