Unchanged:
Ok. Your DS has an IP: 192.168.1.6
So now,
ping 192.168.1.6
This will probably be successful (like above). That means your Mac and DS are on the same network and Roon should see it. Try looking in Roon again. If not there, I would try rebooting your network next. Turn off your “modem” (whatever is your connection to your ISP), your computer, additional routers (if any), and DS. Then restart them in the same order I listed above, waiting several minutes between each item.
If it does not work now, then the problem is a network IP conflict, or something with Roon… so you are making progress!
I don’t know what happened, but suddenly it’s all working. I’m playing Ligeti through Roon right now.
Perhaps that did it. In any event, THANK YOU, everyone who contributed.
