One for the tech gurus. Router Model: Sagemcom f@st 5670v2.
My router, ISP supplied, keeps resetting itself at various points through the day, for no reason. It does not appear to be for firmware updates.
Basically, it soft recycles by itself.
I did Google this and some say it is the power supply. The power supply is one of those typical wall-warts.
There are no indications of power fluctuation in my apartment. My TV stays on and the lights do not flicker when this happens - There is no effect on any of my other electronics… Also, It does not occur when the A/C turns on or off.
Anyone here have similar problems?
And more importantly, has anyone found a solution?
Is it as simple as trying a different wall-wart?
Or getting my own router?
ISP supplied routers (at least here in the UK) are almost always naff.
Unless mandated by the ISP then your own router is probab;y best, safest, etc. etc.
This assumes you are happy configuring a router though
Several years ago I bought a kitchen appliance that appeared to be DOA. But before sending the whole thing back, I decided to purchase a wall wart to replace the one that came with it. Problem solved without the nuisance of returning anything. So I would suggest getting a wart of the same value as the one that came with the router and see what happens.
