Hi, I am looking to buy a S300 for my living room setup. The preamp that it will be used with doesn’t have a trigger output, which got me wondering, what is the lowest voltage that can trigger the relay?
Would 5V be enough? This would enable me to trigger the amp from the switched USB output from the TV…just a thought. I could build or buy something I am sure, but that would be a super simple solution
Thanks!
Jamie
