Short Circuit error message - Power plant 15
Hello! Has anyone else experienced this error when turning on the device? In half of the cases, when I turn on the devices connected to P15 in a chain, the device is disabled. It is important to know that my amplifiers are chained and they are turned on each other with a TRIGGER cable, from standby mode. Sometimes this requires too much starting current? There is definitely no short circuit in the system, something else may be in the background. Can anyone help? Even if they turn on with the delayed start, they only go into standby mode. When I actually turn them on in a chain, this message sometimes appears.
Thanks, Peter.
Welcome
What happens if you unplug everything from the P15, and then turn the unit on?
If the P15 then acts normally I would try each component plugged into the P15 individually and see if you can track down a culprit.
I have a P15 and this was happening to me every 3rd or so time I would power it up.
No shorts, no cable or other PSAudio equipment issues that I could tell.
Having a delayed startup/power sequence seems to have addressed this now. For me at least.
Cheers
Hello I now have this problem. My P15 clicks out and turns off after an hour or so. I get the short circuit message. I checked my circuit breaker and only after tripping it does the P15 turn on. After an hour or so, it clicks off again. Please provide a solution and any help is appreciated.
Hello, What devices did you connect to it? Unfortunately, in my experience, higher-powered amplifiers cause the problem. I was able to reduce the error message (not eliminate it!) by leaving the amplifier on all the time.
I do have 2 Parasound JC-1s. It is just strange that this is a recent development. It still happens when the amps(and others) are left on. I will consider the other traffic.
Tks
Hello, I face a similar issue, sometimes when I switch my solid state amplifier Musical Fidelity A5 and P15 is on well the P15 runs into safety mode and all relevat equipment, including my amplifier are switched off; it seems to me that this is due to the inrush current of my ampli, I guess so, simply because this haappens when I swich the ampli on; on the contrary when I switch P15 on for instance in the morning as a brand new listening session and I swich after that my ampli always via the main fron buttom this is not causing any issue, no shut down of the overall System. How come P15 cannot handle an ampli like mine - 250 wpc and 127 Volt - peak to peak current - this is a mistery to me indeed. Any suggestion other than plugging the ampli into the wall socket rather than into P15 HC? Thanks a lot for your Help!. Orazio P.S. Of course Short circuit message appears when P15 runs into safety mode…
Hi,
I also have a P15 and to avoid the occasional Short Circuit message, I have programmed a delay start on some of the power outlet circuits. This ensures that the initial load demand is not coming in all at once. I don’t believe I’ve had this message since I’ve done this.
This delay setup is done via the screen.
Good luck!
Cheers
Kevin
Hi Kevin,
Following Steve’s recommendation from PS Audio I have decided to keep the state solid amp ON which will be driven oon a ON/OFF status through the main P15 display, by simply pushing the icon and turning ON/OFF the amp whenever required. Apparently this should avoid the Inrush issues which I face if I switch my amp through the main button on it, which to be honest was not happening all the time.
Most probably 75 Amp - peak to peak - from my Amp Musical Fidelity A5 are just to critical to be handled by my P15.
Lets’ see how that works. I will check and revert asap. Cheers
Sounds like it should work.
Good luck.
Cheers
