Silent Windom
Hi folks looking for a little help. Did my Windom update everything seems normal expect for the important detail that I’m not getting any sound.
Level is up fixed at 100%, volume on preamp is up,
I use MControlHD. Check cables and connectors.
I’m out ideas of what to do. Any advice greatly appreciated.
Thanks.
RC.
Input to DS Dac is properly set?
Disaster averted, all is well. After further investigation I have learned that there was an power bump earlier today while I was at work. This deactivated any presets that my preamplifier had and inputs to the pre were turned off. Thank you very much for your replies.
I am now Windom bound…
