While Blue Coast Records is starting to standardize on DSD256… . Perhaps an uprev of the SGCD would fit nicely with the release of the M1200 and Stellar speakers.
Would possibly an upgrade kit for existing units become available? I know some people, like in the Baltic states who’d also be interested.
Agree you’re right on need for gcd upgrade. Seems a real stretch that people purchasing the coming m1200 stellar amps at their price would want to use preamp with features of gcd (inexpensive but if I buy a $5-6k amp I’m not feeding it with ess9010 dac). Worse, lack of compatible quality pre in series likely keeps me from pulling trigger on the m1200s until preamp match fixed.
$6k too much for stellar amps and nobody will pair with existing gcd. But if you revamped and upgraded the gcd and charged $2-3k for it, and cut m1200 to $5k, you’d still get $7.5k for the pair (same as current projected 6 + 1.5 but as mentioned not sure why anyone would use current gcd with m1200). That’s the way to go.
I do like the sound quality of the DAC of the Stellar Gain Cell DAC. Not sure if the DAC chip number is going to make a big audible difference.
Neither am I sure whether I’ll be able to hear an audible difference between DSD 128 and DSD 256 which is the data rate / frequency Blue Coast Records seems to standardize on.
But all above little things together, with others like:
the improved Gain Cell circuit, which will hopefully take care of:
the thumps when switching to and from the HomeCinema input which is set to a different volume level
different levels of DC voltage drift in left and right channel
finally a display that shows the actual file format and bit rate and or frequency through USB
the above mentioned updates on the DAC
and maybe the add on streamer module like in the integrated amp, unless PS Audio plans a separate Stellar Octave server that will take care of the streaming and possibly CD input as well.
These will make an update of the Stellar Gain Cell DAC worthwhile when the Stellar Flagship M1200 will be released.
Cost wise:
I can not see how a Stellar 2 X M1200 + 1 x SGCD combo gets into the cost region of the BHK/DS series.
To get the same features in the BHK/DS series you need:
DS DAC
BHK PreAmp
BHK S250 or to compare apples with apples 2x BHK M300
Add the costs of those together and you’ll realize that you need to save a little longer or create a bigger crater into your savings account for the BHK/DS combo vs. the Stellar combo.
Yet the Stellar package will be capable to drive any demanding low impedance / low efficient speaker of your liking like the BHK’s can, with perhaps a grand of less Sound Quality that some of us might even not be able to really hear.
What I’m saying is I doubt someone spending $6k on amps will pair it with a dated $1.5k preamp commonly available for under $1k, and if that’s right it may limit sales of m1200.
I think a better combo would be a 2.5k upgraded gcd to support the 300, 700 and 1200. And if 1200 went for 5k all the better.
Not too hard to find bhk pre and stereo amp and a dsj All for under 10k right, even all new? I know at least a month ago that easily doable. Not sure today.
If you read other forums where dacs discussed and compared across various manufacturers, for better or worse specific dac chip used and its attenendant specs tend to be important considerations for those in the market for purchasing a new dac or dac/pre combo
Wow, I can assure you, you can absolutely forget those price levels over here in Europe. But you are right at a certain price level it gets over here into highly regarded and top quality Octave Tube amplifiers and could decide to split the digital chain from the pre amp all together, for example by utilizing the AURALiC Altair. I refer to „Octave“ the German brand and trademark, existing long before PS Audio Octave Music services.
As I initially pointed out long ago, it is exceedingly difficult to choose a single word which has not already been registered as a trademark or service mark by someone somewhere.
@Paul: since you have the GCD and S300 on sale for only a few more weeks I have to ask: strictly for sound quality (not functionality) , do you prefer that pair or the Strata since it’s a newer design?
The SGCD and S300 are a good combination. To get the best sound quality possible, you will need balanced connections between the pre and power amps (if you do go that route). I am only guessing, but would expect both the integrated amp and the separates to sound very similar in sound quality. The main difference between the 2 options, is if you are thinking about upgrading in the future, separate components allow for greater flexibility. For instance, if you later decided to upgrade the amp to the (truly wonderful) M700 monoblocks or the M1200 monoblocks (when released), getting separate pre and power amps now would be beneficial. Or if you are tempted by the M700 now, the sale price is a huge bargain for the increase in midrange smoothness. If this one purchase is the final destination, the integrated amp might be the better route to have the pre and power amps in one neat box.
To my ears the sound quality of PS Audio equipment is excellent and as good as I’ve heard, and especially so, for the price. I preferred the musical abilities of the BHK300 amplifiers to the much costlier Constellation amplifiers I owned prior to buying the BHKs. That said, YES, the most unreliable equipment I’ve “ever” owned!
I often wonder if there is a correlation with 230 mains voltage… 230 volts equipment appear to be more problematic!
The DS DAC is in my top 5 best products I’ve owned - which is no small amount.
That’s a tough one, but overall I’d have to pick Strata, The separates combo definitely has more noticeable power, a slight edge of clarity, detail, and size of soundstage, but Strata is the one I keep coming back to for sheer musicality.
I have had 6 PSA products over the last 4 years with no service issues.
My early DMP did burp a few times but was cured by the last update.
PSA’s widening product scope can be a curse or a blessing depending on
your viewpoint. My value orientation is simple, if it sounds better than like
product, is improved by upgrades, and is reliable, I’m good.
You might be right on the 230 volt observation. Although I am only one customer I have quite a few PSA 120v products spread across their line from Sprout to BHK. I have never had any quality or performance issues with any of them.
We have gone through the unfettered bashing of PS Audio multiple times in the past with no benefit to anyone, but with great harm to the forum with many personal attacks, destructive tribalism, etc.
