Based on Ted reply’s, I would contend that we cannot (and should not) judge the revealing quality of a sound system based on it’s ability at controlling the tone using screen dimming scale adjustment. There is no relationship between the two. A system whose tonality is affected by screen dimming adjustment is only indicative of a system that is pervious to RF noise, nothing more.
Based on Ted reply’s, we found that the screen is a big RF radiator (i.e. the screen emits radio frequencies, typically in the MHz range) , with the screen refresh rate being somewhere in the audio bandwidth.
Typically, a Radio station will modulate (AM, FM, PM) the broadcast audio signal onto a high carrier frequency: at the receiver end, the RF signal received by an antenna is demodulated in order to filter out (extract) the audio signal from the carrier frequency.
So, in the case of the DSD DAC, the carrier frequency is the RF emitted by the screen and the audio signal modulated onto the carrier frequency is the rate noise.
Therefore, if any part of your system acts as an antenna (which could be anything: interconnect cables, electronics components inside your amp, speaker wires, …), there is a risk that the RF be captured and then demodulated by your system circuitry (a simple low pass filter is sufficient to demodulate AM signal like the crossovers inside a speaker for example) thus mixing the audible rate noise to the music signal, which can affect the tone.
In my opinion this would mean that if someone owns a system whose tonality is affected by the DSD DAC dimming setting, then it means that some piece in the system is pervious to RF frequencies.
So, if your system remains unaffected by screen dimming adjustment, it is a good thing - no need to worry about the “sensitivity” of your system.
Otherwise, your system has a weak link allowing RF to come-in, and additional shielding is required to fix the problem.
In my case, I added two years ago two sheets of MuMetal 0.010" thick x 8" x 12" underneath my DSD DAC in hope of shielding it from the magnetic field generated by the integrated amplifier located on the shelf below as recommended by PS Audio Scott Schroeder. I would also suspect that the MuMetal sheets also provide shielding to my integrated amplifier from the RF generated by the DSD DAC.
I also have an ifi AC iPurifier plugged into the power outlet of my sound system.
My integrated amplifier has a large thick metal casing that must be providing very good shielding against RF, and the description says that the power amplifier topology keeps out external noise interference.
Lastly, I have Audience speaker cables, which are well shielded/insulated.
By the way, I have found to my hearing (this is only my opinion, not a verifiable fact) that copper wires offer a more natural sound as opposed to silver based (or coated) wires that seem to add an edginess in the highs which I cannot tolerate (listening fatigue).
Hope this help.
