Stacking of PowerPlant, feature difference of PowerPlants
Hi,
I own 2 M700’s and a DSJ. Speakers are GoldenEar Triton Refs.
I am about to buy a PowerPlant and I am wondering:
  • can I stack all components? (except the speakers:)) When would it become an issue for max load?
  • The GoldenEar do have an active subwoofer inside with 1700 W. Considering that they are not always at max power, would it be possible to plug them into the PowerPlant for over voltage protection reasons?
  • Except for the specs, is there any feature difference between the PowerPlant 12 and 15?
Thanks
KR
Chris
Howdy Chris,
Great questions. Stacking is generally okay, though there are some caveats. The big one is where you’ll be stacking them. If it’s in a closet or cabinet with limited airflow and space, stacking might not be appropriate.
If you want to stack things, I’d recommend getting some footers between the Power Plant and everything else. Something like these would be effective without risking scratching the top of the P15: https://www.musicdirect.com/vibration-control/bdr-cones
You can plug your GoldenEar subwoofers directly into the P12 or P15, that would be no problem. As you said, it’s rarely running at max power. We ran the bass towers for the IRS Vs on P10s and the P10s never broke a sweat.
The features don’t change between the P12 and P15, though some folks have been in your shoes and compared the P12 vs the P15 in their own system and the consensus is that the P15 sounds better. The P15 has a more robust output stage and greater energy storage which leads to lower output impedance - this is the main reason for the performance improvement.
Either one will be a big step up over going straight from the wall or from a power conditioner, though.
I hope this helps out! If you have any follow-up questions, I’m happy to assist.
Hi,
ok great. Thanks a lot.
Any other alternative for the BDR cones that I could buy in Europe?
KR
Chris
There are a plethora of options out there depending on budget, material, shape, etc. You can go on the more affordable side and get silicone or sorbothane hemispheres like these - https://www.amazon.co.uk/Hudson-Hi-Fi-Platinum-Hemisphere-Isolation/dp/B079SV39KW/ref=sr_1_8?ie=UTF8&qid=1551196499&sr=8-8&keywords=isolation%2Bfeet%2Bhifi&th=1
If you go that way, I’d do to the 2.5" hemispheres.
Or you can go “audiophile” and pick up something from IsoAcoustic or some of the other big names. You’ll pay a lot more though.
