I have an EverSolo 8 paired with my M700 mono to Focal Theva no2 floorstands, temporarily using a Totem Kin Play 10 sub. Looking for a better pairing, I heard issues with REL with the M700. The PS Audio new sub is tempting but too big for my room. Recomendations?
I’ve been using a single REL T/9i with my M700’s and later with M1200’s using high level input without issue. There a lot of discussion about how to connect - some forum members have used it this way and others warn against it. I’ve not read any reports of hooking up a single REL to M700’s causing problems.
Subs need some dimension to work properly. The PS sub isn’t that large, I would say, but of course I don’t know your listening room’s restrains.
What’s your current sub size and what would you consider an acceptable size?
I use a pair of REL T/7x with my M700s without any problems or difficulty at all. They supplement my Maggie .7s very well. You just need to follow directions for making proper connections to balanced differential monoblocs (don’t connect the subs’ ground cable to the amps’ negative speaker terminals). Also, some people don’t like REL amp controls’ lack of numeric labeling (neither crossover nor volume have markings), but the company believes the ear is the best tool to achieve correct integration.
My listening room is 11.5’ x 10.14’ with 9’ ceilings and hardwood floors partially covered by area rugs. The space features three distinct listening stations, with the primary Hi-Fi setup (Station 2) positioned on the rear wall, where the listening position is approximately 6.5’ from the speakers. A notable acoustic challenge is a permanent 1.17’ air gap on the left wall leading to a garage, along with a sliding wood door and a 2.8" ledge on the rear wall. I am currently integrating a Totem KIN Sub 10, which is placed 1’ from the front wall (Station 1) near a large IKEA Karlby desk, while the rear wall houses a solid wood turntable console centered between the main speakers. Physical treatment currently consists of six Elgato Wave Panels on the left wall.
Thanks folks, I will wait for the Montreal Audo show in March so I can sample different subs. Will keep you posted as you all have been helpful.
I have two REL T/9se subs in Red. They compliment Focal Kanta No3. I employ the wireless kits for both subs. Wireless connection can be tempermental.
REL has a recommendation tool on their website. It might serve as a good starting point.
It’s unlikely that your listening impressions of subwoofers at a show will have much relevance to your own room and speakers. It’s hard enough to gain any meaningful insight with monitor or floorstanding speakers at shows, with subs, nearly impossible IMO. I’ve got JL Audio and REL subs to use in two systems in two different rooms and they don’t sound the same in different room and system contexts. Each brand has its strong points and each sounds excellent, but they are different.
This short article summarizes the problem with making buying decisions at shows very well and I share his sentiments.
https://darko.audio/2025/10/should-you-actually-attend-a-hi-fi-show/
I do like REL’s manual rotating dials. I find them to be wonderful. And yes, the ear is a wonderful tool, if used properly.
I also use a pair of REL T/7x with my KEF R3 Metas and psaidio S300. Love the sound and the blend with the high level connections is seamless and simple. I did buy the wireless module when I had a single sub but never used it. Preferring to go with upgrade cables instead of REL stock.
How are enjoying the Kantas?
Hi. I can recommend rythmik subs. I use them with my Salk BeAT speakers powered by M700s. I use the low level input from my schitt freya+.
Thanks I was not aware of that brand , will look into this.
While this maybe a PS forum and the new Foundry sub will be top of the list… for a long time the Rel range of subs has been the most popular, they might be more expensive than most, but they have been around a long time, so know what they are doing. I have 2 Rel S812’s in a normal size UK lounge, they support my Amphion 7LS speakers. Would I swap them? NO WAY (sorry PSA)
Thanks , I am going to “try” to take my time to go and listen to them before I commit.
BillAudioAI… You have a small listening space like I do. What is your subwoofer crossover set to? Do you use a high pass filter to send only the frequencies above the crossover point to your main speakers? I am asking because I get quite a bit of bass boom/resonance on some songs with my speakers that produce good bass. I am wondering what your experience has been.
On the totem I use 50hz cross over and 30 for phase, but I have a mismatch of the Focal Theva and Totem Sub, there is no real difference to my listening, When I pair it with my Totem Kin Play active speakers the synergy works and there is a good kick to the muisc,
I love my SVS SB3000 sub. Great wireless interface to tune and tight controlled bass (sealed design) for not crazy money.
When using a tool like REW (Room EQ Wizard) and USB mic this sub integrated beautifully with my mains (Sanders Sound Systems Model 10e hybrid ‘stats).
which amp , dac do you have it with?
I use two stereo Sanders Sound Systems Magtech amps and a dBx Venu360 LMS (loudspeaker management system) as an active crossover, EQ, driver time alignment, room correction, etc. One amp drives the ESL panels and one drives the TL woofers.
Digital front end is a Jay’s Audio CDT3-Mk3 CD transport feeding a Mola Mola Tambaqui DAC.
Analog front end is a Rega Naia TT with a Rega Aphelion2 cart feeding a Rega Aura phono preamp.
Line stage preamp is a Pass Labs XP-22.
Very, very happy with the sound of this system and haven’t made any upgrades for some time.
