stunning
My usage habits seem to be pretty evenly split between music listening and movie watching these days. Covid has provided a lot more time for me to do both! Music listening is predominantly in stereo though I do certainly enjoy a great multi-channel DVD-A, SACD, or BD Pure Audio mix.
There are four Seaton Submersive HP subs arranged in pairs along the front and rear walls and located at .25 and .75 of the room width. I use a DSPeaker Anti-Mode 2.0 running in its multi sub mode to provide both a 6ms time alignment delay to the nearer rear sub pair and some targeted parametric EQ for the subwoofer pass band. For stereo listening a JL Audio CR-1 electronic subwoofer crossover looks after the 80Hz division of bass duties between the front ATC pair and subs. For multi-channel listening the Anthem AVM-60 pre-processor performs the crossover duties, again at 80Hz. I do NOT use the ARC room correction in the Anthem. My passive room acoustic efforts do a good job above the subwoofer passband. In both cases the subwoofer outputs are summed into a single “.1” channel before being sent through the DSPeaker AM2.0 and on to the four subwoofers in order to maximize the modal averaging benefits of the distributed bass array.
The JL Audio CR-1 is a game changer IMO! Fantastic piece! Love the room!
I feel exactly the same way about the CR-1. I have owned or been loaned countless electronic crossover solutions over the past 4 decades, of which the higher-end Marchand models and the Bryston 10B Sub were my prior benchmarks. None were genuinely transparent when it came to the high pass section though. The CR-1 is the first electronic subwoofer crossover I’ve used that actually is genuinely transparent in operation. Other than doing its job it simply sounds like it is not in circuit.
I’ve been using electronic crossovers for over 30 years. The Infinity Modulus Subwoofer came with a crossover box. The front has a rotating dial for the subwoofer controls. The back has dip switches that have to be manually set either “up” or “down” for the main amp/speakers to be cut off at 140hz.
My new Parasound P6 also has low and high pass filters that can be adjusted. Haven’t tried them yet.
How do you like your new Halo P6 preamp?
Best wishes
It’s fantastic!!!
I now really, really, really like 3 preamps
I had the P5 and P7. I missed this dials so much when I got the BHK pre that I bought the JLaudio CR1. They work great enjoy how the Parasound can integrate a sub with both 2 ch and HT in one system.
Lots of changes since I last posted a picture of my system (this is in my family room, open to the main part of my home). The only original pieces are the DSD, music hall integrated amp I use to run my deck speakers and the REL subs.
I like the juxtaposition of the typewriter with the modern electronics.
I store my Edison cylinders next to my turntable…
Was the camera hand-held or on a tripod to take this photo?
Just an iPhone I held up at my spot on the couch with the permanent butt indents in the cushions.
I guess that’s why you were able to hold it so precisely, lol
Too neat and tidy, you lunatic!
Great set up. A Pass, multi-chassis pre-amp is on my list to try someday.
Enjoy.
Here’s a picture of the rack reconfigured with the 2 channel on the right and I moved the HT gear to the left. The furman is still in service powering the subwoofer and sending power to the electrostat panels. I also left the doors off in this picture. They are back on now.
I believe I spot a Puritan PSM 156 in addition to a Pass XP-22 and Pass Monoblocks. Very, very nice. What are your impressions regarding the Puritan PSM156, as it has been on my mind as a potential upgrade with my cj tube based analog system. BTW that is one exceptional system, and most handsome indeed!
Just a thought, I wonder how those MLs would sound powered by a P15 and AQ Dragon PCs?
Thanks!!! I love the Puritan. I also have three of their top power cords (gonna get a few more after I catch up $). I think their product is special and, importantly for me, the power cords are super easy to deal with in a rack on wheels. I also bought a 9lb chunk of steel, painted it back, and set it on top of the PSM 156 with some herbies damping washers glued to the bottom. Holm audio is a Puritan dealer, a big fan and sold me on it (live and work 10 minutes from Holm Audio btw).
Small piece of evidence the Puritan is doing something right…with the grounding at least. I had a P20, BHK 300s and REL subs. With the P20, the subs, if left on, would hum slightly (high level connection and BHKs in standby). I used the P20 to shut them off (problem solved). With the Puritan I lost control of the ability to shut the subs off remotely. Turns out, I didn’t need it since it somehow eliminated the hum. RELs at that point, we’re plugged directly into the wall. Also, everything is plugged into a dedicated (2-20A duplex receptacles, one on each side of the system) 20A, isolated ground circuit no matter what.
The KEF Reference 1 complement the REL subs in design. An attractive no compromise system.
