Why don’t team up with these guys, PS Audio?
http://youtu.be/5pWUGCgPCxU
http://www.roomieremote.com/video/iphone-gestures-w-320.mov
http://www.roomieremote.com/features/
The Bridge needs to develop its HTTP commands via this IOS SDK:
http://www.roomieremote.com/faq/#customDevice
Put the PWD in their Library for the user to select it as the control point - and Voila!
Looks somewhat similar to XBMC - I’ve downloaded but not seen yet whether I can get it to work with the PWD
Looks somewhat similar to XBMC - I've downloaded but not seen yet whether I can get it to work with the PWD
Just to be clear on it (based on the slightly confusing title), my idea was to use this for an iDevice version of valer_valer's PWD control app. for Windows and not an uPNP server control point. If I get access to these codes I might try to make something.
I am able to do this via IR control with Roomie today.
What I also want is to assign the PWD remote control from the Roomie library and control the PWD via LAN, inclusive of feedback for most parameters (e.g. set volume).
All you need to do is to assign the Remote and you are good to go since everything is preprogrammed.
The trouble with this is that the PWD does not allow control via RS232, so you are left with the Bridge status and control.
Got you now. Yes, I’ve suggested this before - take that windows device and make a nice app out of it. It would be useful.
