To regenerator or not delimma
The P10 was a nice upgrade and the P20 even better.
P15 arrived and got connected today. Slightly lighter than one of my former power amps :smiley: My mains are balanced 230v (115 + 115). THD in ranges between 0.5% and 0.8%, THD out is flat 0.1%. Analogue and digital playback improved remarkably and I expect more as the unit breaks-in. There is no audible RF / EM induced interference at all. Thank you all for your advice and support.
Congratulations Serhan…it has been a long time on the trail coming home to you!!
I know you would like for it to burn in…but…
Initially anything improved musically?
Just had to ask you know…
Ooops just didn’t read well enough about playback improved significantly…
Glad to hear that it has…
Darn it just blew a fuse in my P10, now have to wait for Amazon to deliver!
Yeah, I Know the feeling. I hope you get it soon. I keep a spare.
Can you recall what triggered your P10s fuse to blow?
We’ve been having power outage issues here, that’s probably the cause.
Yes disconnection and sudden reconnection does that somtimes!
I received the new fuses today and when put in a new one in it blew right away. Does anyone no what the problem might be?
Could your new fuses be a fast blow vs a T or slow blow type?
A fast blow will not likely withstand initial inrush current on power up…
5x20mm 5A 250V Slow-Blow Ceramic Fuses 5 amp
Zardozm…would be good to chat with whizkid jamesh…to help get
to the bottom of this issue…
Wish you the best for quick resolve!!
Just a process question but what are Mr on/off switch and Mr power cable doing when you turn it back on? If your switch is set to on and you plug it in, well, poof.
Those are the correct fuse values for the P10. Can you tell for sure that the fuses say 5A?
The fuses are stamped T5AH250V.
Yes the unit was unplugged and off.
Thanks Zardo. I just got a note from the service team that we’re bring that guy in. Let’s hope for a speedy repair!
I’m waiting on TJ’s email for the service # and shipping info.
That was fast and excellent response…
Way to go !!
I decided to go with a preowned P10 regenerator and I can say I have no regrets! It seems like after being plugged in for a week it has really settled in! All the components hooked up to the P10 sound much cleaner and accurate! I’ll borrow the lifting veil off the speakers reference because it fits with the regenerator upgrade. I didn’t think it could get much better and it has! The P10 came with the stock fuse so I will be installing a SR Orange fuse tomorrow! If your on the fence about putting a regenerator in your system it’s definitely worth a try! I’m happy I did!
Glad you got your P10…the Orange fuse will make a good
difference :smiley: :+1:
