Too much for P15?
Hey! Upgrading from a P5 to a P15. Just want to make sure I’m not pushing the P15 to it’s max. Currently everything but the subs is on the P5 and I’m running at 90% capacity. Thanks!
  1. Primaluna Dialogue Premium HP Mono (running NOS Winged Cs similar output of KT88s)
  2. Primaluna Dialogue Premium HP Mono (running NOS Winged Cs similar output of KT88s)
  3. BHK Pre Amp
  4. Direct Stream Senior DAC
  5. Intel NUC
  6. Ethernet Router
  7. Rel T9i Subwoofer
  8. Rel T9i Subwoofer
It appears that the P5 is rated at 1000 Volt-Amps for a
continuous load.
It appears that the P15 is rated at 1200 Volt-Amps for a
continuous load.
Therefore your load would theoretically be reduced from 90% to 75% using the P15.
I have the same amps, with the Primaluna pre the DSD,DMP and Stellar PP. my P20’s runs.! I don’t run my subs through it .image|375x500
