Turning off DHCP/Static IP
Hi guys,
Sorry if this procedure is obvious, but I have searched the forum and manuals and haven’t found out how to turn off DHCP on the PWD bridge (IOW, to set a static IP address)- there must be something I’m missing. Any help appreciated!
OK, the bridge has to be connected through USB to change its settings. Now I get that part of it, at least.nerd_gif
apsprtim said OK, the bridge has to be connected through USB to change its settings. Now I get that part of it, at least.nerd_gif
With the Bridge connected by “ethernet” cable you can access by the front panel or by the Bridge web page.
Get the IP address of the Bridge and enter it in the address bar of a web browser.
Under network settings you will see a DHCP box. Just enter yes or no based on your preference.
Yes means Dynamic IP and no means static.
Reserving the same IP in your router may also help.
yes, I can be pretty dim sometimes. But I have found the settings page so I guess I’m set for now. Thanks for your patience-
