What fuses should I use for my P20?
I have a P20 powering a McIntosh 200w amplifier and a Yamaha Reciever I also have all my sources connected to the P20 and the tv, what fuses do you recommend for my setup?
For the P20? If you can ascertain differences between fuses, then either the Audio Magic M2 or the Synergistic Research Master or Pink. All three are different. Which one works best for you is something only you can decide.
When I had my P15, I preferred AM M2 fuse over their M1, and over any of SR fuses including Purple and Master.
That’s an expensive suggestion!
But not expensive for Tony :rofl:
Well you asked so here’s my two cents: Stick with the stock fuse and spend the money elsewhere.
Solution. I have an Audio Magic M1 fuse, 6.3A,
that powered my P20. $75. PM me.
Replaced by an M2. Do not recall any improvement
other than 2 is larger than 1.
Wow. Take that deal! I had an M1 in my P15 and it was the best fuse. Only a Swiss Digital Fuse Box with a Graphene Sluggo really was better.
