Which powercords are you guys using for your P12, P15s or P20s ? thanks!
Take a look at NRG Custom Cables. I am using the .1 CS from the wall to my P5 and also to my Dutch & Dutch 8cs. They are quite flexible for their size. He will make them to custom lengths as well.
http://www.nrgcustomcables.ca
I am very happy with mine. I got them for the 8cs given their flexibility and reviews.
Thanks Lonson your guesstimate is good enough to get an idea
AC-12. That was easy…Smile!
I have a P15 and use AQ Monsoon which I think gives good ā€˜bang for the bucks’.
From the wall to P12 Pangea AC9Se MkII
From P12 to Parasound A21 Pangea AC9Se MkII
From P12 to everything else Pangea AC14se MkII or AC14Se XL
They deliver the PRAT!!
Hi David,
Just curious if you have compared the Pangea AC9SE to the AC9? And if you still have and use the AC9SE? I’m concerned that these Pangea cables aren’t very flexible, as my Stellar needs to be 9 inches off the wall.
Anyone try SignalCable power cable with their Power Plant?
http://www.signalcable.com/power_cables.html
George when researching the Pangeas and found the the MkII version their
latest and top of the line …I wasted no $$$ on the non MkII version didn’t
want to monkey around back and forth.
I still have and use all my Pangea power cables…not looking to
change anytime soon.
The longer lengths of the 9MkIIs will help accomodate shorter radius turns…
in you case you may benefit with AC14SE MkIIs…same build specs just smaller
gauge…
Might be worth looking at
Happy hunting
