I’m an old audiophile trying to keep up. I purchased a Sprout 100 for our living room paired with Klipsch 600m ii speakers.
I’m streaming Tidal via Bluetooth.
Will a WiFi streamer benefit me? Recommendations?
Also, how does it connect to the sprout? Assuming it would then be the digital option?
Old dog trying to learn new tricks.
Welcome!
In general, Wi-Fi/LAN transmission of digital music signals will outperform Bluetooth sound quality (in my experience).
If you want to upgrade your sound quality experience, you might want to consider your options.
Hoping others will join in here.
Welcome to the forum.
I think you will hear an improvement vs Bluetooth with a WiFi streamer. I notice the Sprout has an optical digital input so a low cost/risk option would be the Wiim Mini at $89 which will give you Tidal. There is also a USB input on the Sprout which goes to higher resolutions so an upgrade path would be a streamer with USB out which you may want to consider later on. Hope this helps
