http://www.tweekgeek.com/audio-components/power-amplifiers/audience-wavepower/wavepower-ii/
$18k?
Output impedance – less than 3 milliohms
- impressive
Power bandwidth – DC to 35kHz +/- 3dB
- plus or minus 3dB?! Let’s hope it does much better 20 to 20kHz.
@Elk, Don’t You like sound of DC
I suspect that he prefers the sound of his home.
J.P.
valer_valer said: Don't You like sound of DC :) ?
I question the spec as plus or minus 3dB for an amplifier is far from good. However, the amp may be flat up to 30kHz (for example) and only then drift 3dB from flat. Unfortunately, they do not publish a frequency response chart.
