It’s all about tubes for me. Solid state that I can afford has never satisfied me.
I do have one solid state amplification I like on hand in one system: a PS Audio GCHA. I have a modded DSD Mk1 and a Bottlehead Foreplay III in front of it right now and it is perfect for the ZMF Ori I use it with.
Yep. I’ve read that some have said the new circular connectored umbilical used by Pass is way better than the old DB-25, and shouldn’t show any improvement with an upgrade, but I figured I’d have one on hand and give it a try.
Will do. It’ll be a while, maybe a few weeks. I still have a couple more days of cooking the ‘22 before I even put it in my system, and then it will be with the stock cable.
My P15 is totally full. With the newly ordered RJ45/F.O. converter that requires another power plug, every receptacle of the P15 will be occupied. I never thought this would happen, but here I am.
I cannot have another device that needs power without adding a conditioner or getting a P20 upgrade. I do not even have any analog gear in the system.
Okay the Ali express Silver 5N Cat8 1.5m arrived I placed it between router/switch.and the bacch4 mac Audiophile in place of Inakustik Referenz Ethernet
Tone and Timbre is promising but depth and separation of voice’s and Instruments not to caliber of the Inakustik Cat7 Referenz but it is zero hours I will let it run in some knowing what it takes for a silver digital cable to develop.
If it doesn’t better I will trial it between the router and streamer server. It did sound better than the BJC cat 6A i also had available
You are not comparing it to the Inakustik Cat. 7 silver cable right? I have the same Cat7 Referenz cable in the system and I like the 5N silver cable a lot better. In a day or two it should improve quite a bit in SQ.
The pure silver reference USB is in sameplace. Comparing it to equivalent priced Inakustik Referenz ethernet that is copper plated silver and cotton dielectric.
I forgot that you have the USB, not ethernet. So we have the same Inakustik Ref. ethernet cable. Let me know in a couple of days which one you like better then.
I run USB from BACCH4MACt ti DS Mk2. Ethernet chain elsewhere in streaming. Router switch to SGC i5 sonictransporter router/switch to Bacch4mac is ethernet too.
Our setup is entirely different, and I do not have BACCH (yet). So, I really have no idea how this 5N silver will work in your system. But I hope it is a worthy one
If it doesn’t open up I will try it between router and switch. Music moves twice on that ethernet cable once both directions. The Ali expres silver cable shows it is directional with arrows. Did you notice that?
