If you use the last two outlets on a Stellar Plant P3 in HC mode, is the output resistance still less than 0.008% that Stellar Plant P3 is specified for? You might well be led to believe that the resistance increases because a filter is activated.
Yes, inherent to conditioners/filters, the HC zone when set to HC mode on the P3 will have a higher output impedance compared to the other regen zones. Or compared to when it’s set to regen.
