As good as presented?
having found first hand the benefits of power conditioning, can the wall plug be this good? black and white improvement?
PSA has a much less expensive plug, build looks nearly as good
The build may be as good, but copper is 4 times more conductive than nickel.
Nothing is better than Power Regeneration. Just ask Paul.
The plating (Ni) is so thin it hardly matters what its resistance is. These are price competitive with other hospital grade outlets. Possibly the most important feature is how tightly they grip the inserted plug. These are just right and the build quality is top notch. Just installed three of them. Be aware that they are 20 A outlets and should not be used with typical 14 gauge wire.
