Hmmm. Ok, what would be the optimum maximum file size to code into the program? Can’t be too crazy.
I don’t remember the limits but I used a 440 x 600 77k file on the old board. The original was 781 x 1045 220k, but I don’t remember if I had to shrink it to 77k or if I was just being kind to the board .
How about using what was there before. What ever it worked. Remeber we all want to feel as others will know us. And avatar is part of it.
The tiny pics that are there now a far smaller than any other sites I attend . Also when will we be fixing the zoom function for iPads and phones.
I am 57 and do not need reading glasses but this is straining especially in the morning or at night . I am sorry for complaining but do feel what we this fixed soon. What we
had before was far better than this is now . There are plenty of well thought out sites to model this one from. Ask me I can give you two that are very well thought out. . I do hope this is a evolution of ongoing fixing and adding and not here is the new forum with more smiley faces as the main improvement. I think someone from ps audio or website managing should be attached to this thread and others like it. And Paul this should not fall on you , you should be selling product and getting input on audio.
We can’t go back to the old one because it couldn’t integrate with a common database for the website. Sorry. Not an option. We will fix the avatar sizes and the loading limitations.
We have a support ticket for the animated smileys that don’t work and will fix that as well.
Patience. I still like the functionality of this forum better, well, mostly. We’ll make it better than the last one, but it takes time. I am sure no one remembers but the last forum was universally hated until we got the right plugins going, reskinned it and put some work into it. This is worth the effort.
I truly appreciate the help and understanding from the members.
Ok guys, Avatar problem should be fixed. You may have to re upload your avatar since the original you put in was scaled to on 50 pixels. The new avatars are twice that size at 100x100 pixels and seem to be big enough to me. Let me know.
Also the maximum file size has been increase by 10X. This should be fine. I can change if you need.
Paul I will email you what worked and what does not. Infuse the same avatars on mNy forums and have never had any reject them. Now what they do when it is uploaded I do not know. Also they should be a little larger on the screen . Also they should be enlarged when you touch them. It’s not that it’s all,important but pep
