Bassline Blue Line Array Connectors
Can anyone direct me to or provide a wiring diagram for the Bassline Blue Line Array Connectors? Rel doesn’t provide them - perhaps so noone can make a custom pair, which is my goal…..
I would just buy and use official REL cables/connectors. Blowing up an amp is not a risk that I would take by trying to save a penny.
good point… headed that way
Bluejeans cables makes a great REL cable! Check them out, reasonably priced too.
I have upgraded my REL high level cables numerous times. Started with a $550 cable. It seemed nice but no big deal. Then I upgraded to a $3000 cable. It seems nice but no big deal. The cables REL supplies are solid copper wire. I don’t believe the signal that travels down these cables is anything difficult for any wire. If I had it to do all over again I would stick with the REL supplied cable. I know EVERYONE else probably disagrees with me on this. But, I did spend almost $6K on the pair I have now. My bunny ate and destroyed one and I bought another of the same cable to replace it. That was dumb. Spend money on music instead.
Just saying..
Just found out the new Rel subs are not backwards compatible…so if you have 2 S/510s or whatever and want a stack, Rel suggested trading them in and to buy 4 new Rels… well I guess I don’t need to think about their array cable anymore because PS Audio has the new foundry and since I will need to buy 4 anyway….Rel basically helped me choose to purchase a pair of Foundry F12s (can’t wait to tell my wife how much money we’ll save!)
:laughing:
