New Rel sub finally here
I have been seeking another Rel sub the S8/12 in particular, after my poor regard for having to use the Low Level RCA connection after getting a pair of M700 amps ( S300 previously). So the dealer came yesterday, and wired everything up right, going back to the High Level Neutrik connections (obviously one sub per amp connection) Was Time to give them a test run, so on with my favourite Pipe Organ tracks, recorded with a lot of 32’ 16 Hz fundamentals going on. Then played some AC/DC and Dire Straits to show some of the bass content on my "go to " tracks… WOW, I was blown away, not just by the sheer deep tight bass, but also some of the improved mid to low frequencies.
I do not have a very high end system, (Amphion Argon 3LS speakers) but its what I can afford.
I might get a pair of them myself. I want white ones though.
I also have been bitten hard by a pair of Rel subwoofers! Life will never be the same I’m afraid. Enjoy the 812’s!
That is a lovely rig. Congratulations!
Thank you
I have a pair of Rel S510s. What that did to my system was intense. Like @paul172 said, life (and my stereo) will never be the same.
The high level connection is very underrated! I can’t believe what it does to a two channel set up. I’ve had SVS SB16 and now JL Audio Fathom 113’s x2. Borrowing @minnesotafats No. 25 subwoofers has been transformational! The biggest upgrade is still the P20 it improved every component two channel and home theater. The Rel 25’s are a very close second! Something tells me the line array of subs would move it past the P20 in my personal ranking!! I’m ruined. If some don’t already know I own line source electrostats and the subwoofer is a must!! The Rel is the best I’ve heard.
Nice kit, and with the underrated (IMO) Anthem processor (ARC is the bomb), I’ll bet you have the speakers and subs dialed in nicely with the strengths and weaknesses of your current room/room set up.
Enjoy.
Congratulations…nice subs
Welcome to the Dual Rel S812 family my second one still in box with some Iconoclast BAV REL cables sitting on top of the unopened box - need to find some time in my life :frowning: - next weekend for sure
Nice looking system :slight_smile: just got sexier
Now you need another two so you can stack 4 subs!
noooooooooooooo, 2 is quite enough, am not Rockefeller :grin:
Nice Setup. What brand are your tower speakers? I would like to check them out.
they are the Amphion 3LS, superb speakers, a lot more would have to be spent to get better imho Argon3LS – Amphion Loudspeakers
Speaker Review: Amphion Argon 3LS - YouTube :+1:t2:
Just added my 2nd REL S510 (an open box special - so glad to avoid TMR Audio after bad experiences) and it has made an improvement over a single sub, but dialing it in is taking some huge effort with gain adjustments not really affecting the new sub as much as the one i’ve had for about a year…
any thoughts ? this a break in issue perhaps?
must add: it is already making me like my Confidence 20s more although I was considering a switch… might have ‘saved’ some money in the spend…
since 3 years ago, I have changed speakers, from the same family, the Amphion 7LS. The dealer who I bought them (all the speakers) from was trained by the UK’s top bloke from Rel, so he has them dialed in perfect, in other words one does not know they are there, until they are switched off. My next step will probably be “uprated” high level cables, see if there is a noticeable difference
