Hi all,
I’d like to share my observations so far. I’ve tried several setups. I first tried using jRiver 20 as I thought that might be the easiest to test with. I’ve used jRiver for years before recently switching to ROON. At this point I’m using Legacy Audio’s Wavelet. It is a combination of preamp, DAC, digital crossover, and DSP and is the brain of my Legacy V speakers. For whatever reasons I never could get music to play. The Lan Rovers lights displayed they were synched. jRiver could not find my DAC. I also tried jRiver with the addition of jPlay. All the settings seemed to be correct except the Wavelet was never discovered. Drat I had wanted to use this as a baseline for the setup I really wanted to try. Darn!
And what would that be? A combo of ROON server installed on my 10 tb WSY2K12V2 server, HQPlayer installed on a WIndows 10 pro Zuma Clone PC with both systems running the AudiophileOptimizer and Fidelizer, the Sonore mRendu, and the Lan Rover. I used Ethernet and a gigabyte switch with a linear power supply to connect all the components.
I plugged the mRendu output via my Lampizator Silver USB cable into the Lan Rover then Cat 7 Ethernet made the connection between the Lan Rovers, then from Lan Rover into the Wavelet via a Clarus Crimson USB cable.
Much to my surprise both HQPlayer and ROON synched and found the Wavelet. All the Lan Rover LEDs said action, and I played the first cut a 24/96 version of Fleetwood Mac’s “Oh Daddy”. While not SOTA I like to listen to Buckingham’s guitar work and the drum work of Fleetwood and McVie’s voice as she sings, Oh, Daddy. They repeat this combo several times in the cut so it’s easy to find. What did I hear? Could the mRendu and Lan Rover do something special together? (If you haven’t heard what the mRendu as NAA for HQPlayer can do you might want to check it out if you get a chance. It certainly outperforms my fancy USB card with linear power supply.)
Much to my surprise and consternation (I was hoping I wouldn’t want to buy one.) the Lan Rover easily elevated the mRendu’s performance. At first listen I heard 3 different areas that really stood out, the soundstage became deeper front to back and it was easy to hear the original room’s boundaries. Next, the sound across the audio spectrum became full fleshed and vibrant, and last (really in no special order) the bass (powered by about 3,000 watts per channel) just became fuller, richer, and more dynamic. The band was in the room. I quickly played my favorite cuts from Gladiator, Casino Royale, Diana Krall, Louie Armstrong, Ella, Johnny Cash, and my new favorite soundtrack, Brendan and the Secret of Kells. The Lan Rover and mRendu performed their magic on all.
Ok so how much real difference was there? In reality in probably small to the casual listener but too audiophiles the Lan Rover was quite an upgrade especially its ability to project the soundstage and images correctly. Can’t wait until Lampi comes back from an upgrade so it and the Dude can perform their magic. I’ll probably be able to each out and touch the performers then!
be glad to answer any questions and provide more setup data on request.
