I just started using the PWD DAC II with Bridge for the first time this weekend. In setting it up, I’m having an issue in foobar2000 where, after around 10 seconds of playback through the bridge, the sound drops out completely. It seems like it must be a configuration issue, as JRiver is working just fine. So one solution is to just use JRiver, though I really want to use foobar.
Here’s the setup I have:
PWD DAC II, v 2.4.4
Bridge, v2.15
Bridge is connected directly to the router, and uses DHCP
Laptop with foobar installed is on a wireless network
foobar has foo_out_upnp installed
The song being played is on the laptop’s local disk
The laptop can see bridge in foobar with no problems. When I play a song to the bridge, everything is initially fine. Around 9 seconds in, the playing time clock in foobar stops. Then a few seconds after that, I lose sound in my speakers.
Any thoughts on what might be happening? The fact that JRiver is perfectly fine has me thinking it’s a config issue somewhere in foobar.
