Does the Perfect Wave Transport play SACD‘s?
Hi all, I just bought a PS Audio Direct Stream DAC MKII and i am very happy with it. Yesterday I got the opportunity to buy a Perfect Wave Transport (build 2016). As I do have about 20 SACD‘s I am thinking about buying it and connect it via I2S to my MKII. Unfortunately I did not find anything about the Transport if it plays SACD‘s. Only if yes it will make sense to buy it. Can anyone help me ? Thank you
@jamesh ??
PerfectWave Transport (PWT) is a redbook/CD transport. Only the later two versions, DirectStream Memory Player (DMP) and PerfectWave SACD Transport (PST) can play SACD.
Link to thread on the differences between the three (and James’s response): PS Audio CD Transport clarification - #6 by jamesh
Ok, thank you very much for your help
Thanks Carbon! You’re exactly right.
Actually the original PWT will also play high res and dop(dsd) files recorded on a dvd as well as redbook cd’s. It will not play the dsd layer of an SACD.
The original PWT will quickly load a dvd recorded with either high rez pcm or dop dsd in 10 seconds. Same as a cd!
The PST will play a dvd with high rez pcm or dop dsd but takes 41 seconds to load the disk!
