DS Junior - "Forced volume adjustment"
As you know I am ultra satisfied with the Junior, first product I buy from the company and really, really pleased.
The only thing happening from time to time (I’d say it’s occured some 20 times or so for no apparent reason) is a minor nuisance with the volume. While playing back (I use digital coax and USB mostly, not sure if it’s the same with the other input options) sometimes volume just goes down automatically and set to 60, no matter if I was playing at 100, or 90, or 75 or 61 -led indicator gets set on 60.
Is this normal, say, some kind of anti-clipping feature or something? Normally I listen at moderate to low volume levels.
EfeTe said As you know I am ultra satisfied with the Junior, first product I buy from the company and really, really pleased.
What version of code is on your DSjr? It sounds like the bridge is setting the volume when you are another input.
eMail me at dennis@psaudio.com
Dennis
I did Dennis -on August 18th?
I have had this happen to me as well. It has only happened when the network input was lost. I have had to unplug my network with on two occasions and both times the lack of network input caused the DS Jr to drop from 100 to 60. It’s annoying but I can live with it since it so seldom happens.
jaiello said I have had this happen to me as well. It has only happened when the network input was lost. I have had to unplug my network with on two occasions and both times the lack of network input caused the DS Jr to drop from 100 to 60. It's annoying but I can live with it since it so seldom happens.
This will be fixed in a future version of Dsjr code.
Dennis
