DSD encapsulated to PCM?
Why need DSD Jr to convert DSD to PCM in order to communicate through Roon?
Am I wrong with settings?
No the settings are correct. DOP is just used to stream DSD - the DAC reads it as DSD.
DSD isn’t being converted to PCM: DSD being smuggled to the DAC thru a system that only expects PCM, think of the PCM as an envelope around the DSD that’s opened by the DAC to get the original DSD bits.
Thanks guys and Ted. Got it.
Yes good information, I had the same question.
Smuggled is a excellent description of the process @tedsmith. Great choice of words!
I ā€œthinkā€ if you turn off volume leveling and any other DSP settings in Roon the stream will go straight thru as DSF/DSD64 without encapsulation. Not sure if it will sound any different.
Vern - I did get the DSD version of ā€œJazz at the Pawnshopā€, then tested it by adding auto volume level and filter w/ Matrix. Going into BII might have been DOP… don’t know, forgot when I had BII hooked up to N+. I do remember seeing DOP…
Richard, I dont remember either. Here is what I show without DSP:
And with DSP
Not sure what it means though. :thinking:
Now,I’m lost
Are you guys streaming through Bridge II ?
Why your signal is not encapsulated ?
I am using Roon > Nucleus + playing thru Matrix to DSJr via I2S. I ā€œthinkā€ the results were the same (memory is no good) with Bridge 2 but it will only do DSD64 max.
@MariusP - I’m using Roon > Nucleus+ playing thru Matrix to DSD via I2S; "thinkā€ the results were the same (I’m officially an old person this summer so my memory is not as good as it once was; grew up last century) with BII; however, the BII will only do single DSD max while the I2S input is double DSD… hope this helps…
I think the difference may be in the use of an I2S connection via the matrix - whereas DOP is usually over USB.
