Great; was wondering about cover durability b/c my son is in the market for a good office/work chair.
I have been very pleased with the Steelcase Gesture.
Yes - this is not on Topic for the Thread strictly speaking, though I think it would make a great Listening Chair as well. I did in fact try it at one point. However, as an office chair, for most stereo setups, even at its fully lowest point, it sits you significantly higher than a typical ālistening chairā like the Eames (which is comfy, but which I have difficulty getting out of, being 6ā3"). This would obviously vary depending on the distance from your butt to your ears.
This is an Embody, which easily smoked the Aeron for me. Dunno about the rest, many of which are new to me.
I used an Aeron for quite some time as an office chair. I actually never did like it.
Used an Aeron chair in my office since 2004. The arm rest cracked after 16 years and the warranty was only 12 years, so forced to buy another one.
Itās really designed for desk work - the cantilever provides the support directly under the base of the spine, which is why it works - and also where a chunk of the cost is.
Bought my son one for lockdown.
Thatās what I used it for, at work. Didnāt like it. ![]()
Your post was right on topic for me. I lift my favorite listening chair on blocks that are 8 inches high to lift me out of a bass room node. I thought of shopping for an adjustable barber chair. Now I may look for an acceptable looking adjustable low back office chair. Thinking I can simply roll it out of a corner when I get into serious listening mode.
Might be worth a look. And be potentially less hazardousš Iād though about finding a barber chair before as well.
Have to measure your ear height now and be sure the office chair goes that high as well - just as mine wonāt go low enough for my stereo.
Iād imagine the mbls are less fussy with regard to ear height vs. regular drivers. I could raise my speakers, but like where they are and what theyāre on, and have a decent comfy listening chair.
You are correct with the MBLās as less fussy with the mids and high frequency range but bass waves under 100hz are the same for every speaker. My rooms is large but the 8ft height creates funky bass nodesā¦and 8 inches in height lifts me out of one of those nodesā¦
Klaussner swivel glider is THE chair.
Well padded with great support and perfect arm rest height. It swivels and rocks. It has a lower back so the rear wall reflections are not blocked.
I promise it will be you favorite music listening chair!
https://www.klaussner.com/klaussner-swivel-chair/12-swgl-328/renderimage.aspx?BODY=ABIE%20IVORY&WallColor=&FloorColor=&FloorCovering=&TrimColor=&WallHeight=50&TrimHeight=5&_rwidth=0&_rheight=0
Ooh, thatās a nice looking chair! Where does one get such a thing?
Hey, thereās a furniture retailer near me that carries Klaussner!
Go to the Klaussner.com web site. Search for swivel glider chair. Not inexpensive, but neither is it exorbitant. it is so good it will be an heirloom.
Archie-
I bet some of the sounds are less than polite sounding ![]()
Iāve been wondering if the table next to the chair is a mini-fridge.
Last November I got myself a Stressless Admiral with the upgraded tilt/swivel base. Found a dealer in my city that was actually willing to discount them. Great guy. We talked a bit about Magneplanars when he delivered the chair and set it up in the listening room.
The chair has pretty firm padding, which Iām liking, and decent lumbar support, though not as pronounced as the lumbar support in the IKEA Poang it replaced (the painterās tape on the floor marks where the back of the Poang skids were). The top of the headrest when itās at its lowest is the same height for me as the top of the Poang, right at ear-lobe height, so no damage done there. Best of all, it sits considerably higher than the Poang, which makes it easier to get out of, and it puts my ears very close to the midpoint of the Maggies, making the aural image sound a bit taller.
Nice choice. It is supper critical to get your ear in the middle of the membrane on Maggieās, which you apparently know. Now, do you have the stock stands, or do you have them off the floor? Didnāt want you to get too comfortable
Happy Cake Day!
@straightwire
Happy
day!
