Do you think isolation feet on the p20 will be beneficial for its performance? If so what do recommend?
I have VooDoo Iso-pods under mine because I do hear an improvement. But like any tweak, it’s minor.
Thx
I have Stack Audio CSA3’s under mine.
The 3’s take the heaviest load, can’t remember if I’ve 3 or 4 under my P20.
They work very well.
I had Iso-Pods under my P15 and then moved to Stack Audio feet. . . and then after I sold it I use those same feet under the components that replaced it. They made and make a difference.
When I had the P15, I heard a noticeable improvement from using isolation footers. I tried a few and they all made various degrees of improvement. So, you should try them.
Currently I put four Stack EQ 1 under the feet of Gryphon PowerZone, and they improve the sound as well. I believe using Stack EQ3 under P20 will benefit the sound for sure, and they maybe one of the best out there with a more sensible pricing.
